E6 vs E7s...
what are the main differences? valve size? port size? CCs?
and can E6s be made to use Roller Rockers just as easy as E7s?
and...could one swap say E7 heads and 1.7 RRs onto a lopo motor, not changing cam and keep the stock ECU and 14lb injectors with no problems?
I was just thinking if I was to find a really cheap box to drive as a DD I would want to experiment with it and get it to pull nicer but get the best mpg possible.
