I have gotten the injectors cleaned out, there is a new fuel pump and air filter and fuel filter in. I dont know why the car keeps stalling out! I had a remote start installed and it started happening after that. I plan on bringing it back to the place i got it installed but I was wondering if anyone had any ideas on what it could be.
Ok my crown vic is still stalling!!
how were the injectors cleaned? sounds like the IAC is acting up on it. i would pull the upper intake and clean the crap out of it and pull the various parts off and clean them as well. while the upper is off, i would clean out the lower intake with carb clean and a smallre type brass brush and do an oil change. after starting, it will hesitate some till it clears all the carbon out you cleaned and will make for a dark smoke show due to the carbon burning its way out of the engine.
is it idleing at the right speed?
faulty spark plugs, gap, wires
vacuuum leak, you check for them with a stethoscope or soapy water. make the bolts on intake manifold are tight and not leakingOnt And Canada PPL The Cookhouse in Dwight
91 Grand Marq . . . . . . 88 ho wagon (project) . . . . . . 80' Lincoln Mark VI
it is a 20 year old car... had an issue after an oil change on a car... came to find out the bad oil leak wasnt due to the oil change but due to a oil pressure sensor that went bad just above the oil filter. swore it was the oil change that was done since it never leaked that before and was coming out from what looked to be the filter.
ok 86vickylx I am not tech guy but I am a panther and if you new anything you know my 86 crown is a multi fuel port injection not try to bash ya just keep up with it. I dont post alot and the vic is in my sig.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Originally posted by 83countrysquire View Postok 86vickylx I am not tech guy but I am a panther and if you new anything you know my 86 crown is a multi fuel port injection not try to bash ya just keep up with it. I dont post alot and the vic is in my sig.
try roofing in this shit!
Therefore
i'm hottest,
in a sexy way.
And whats July gunna be like??
I think you should take it back to the installers before they forget what they did to your beautiful car.Ont And Canada PPL The Cookhouse in Dwight
If the problem started after the remote start was installed, I'd have to think its related. Could be that they somehow screwed up the wiring that runs the IAC or one of the sensors. A code check should come up with something if thats the case, you'd get something about unable to control idle, or codes for sensors that aren't working.86 Lincoln Town Car (Galactica).
My car started stalling the day my remote start was installed and it ended up being the ignition switch. The car would stall or lose power to accessories and gauages and would sometimes kick back on if I jiggled the key some. Two main peices of the ignition switch loosen up over time and the contacts get dirty and worn. When the installers tapped into the wiring, probably just below the switch, they likely made it worse but if it's original it's prob due for a change. When you get a chance, take the shroud off and see what shape its in. I got my replacement Motorcraft switch Rockauto a good price and it was very easy to change.sigpic
1986 Grand Marquis LS 2 Door
oh i had that problem too, though the ignition wasn't cutting out. the radio would spaz over bumps and the turn signals went intermittant, followed by the dash lights going out. This all happened over the course of about 2 days. The switch wasn't pulling apart like I usually see in pics, but internally the contacts were fried. New Motorcraft switch at the parts store fixed it up nicely.86 Lincoln Town Car (Galactica).
