door sticker -- decode?
    I know the paint code 6Q (Deep Sandalwood Metallic) and that she was born 4-88.
    What I need to know:
    1. VR(vinyl roof): YK
    2. Int. Trim: YP
    3. Tape: H
    4. TR: THGGG
    All info is appreciated.
    Justin
    if the codes are the same from the 1981 year, i can tell you cuz i have the ford manuals(vol. A, D, G and the spec book)
      i can tell you that the...
      YR-valino half, but the color isent listed in my book.
      int. trim-vinyl split bench, light pewter color.
      TR-AOD, and the HGGG isent showen in my book.
      this is from the 1981 model year so it might not be accurate, but hope this helps a bit.
        hey man this from the 1990 shop manual
        vr-vk=pastel alabaster
        it-yp=hmm, there is no yp listed. y by itself is shadow blue. p by itself is light sandalwood. the y in yp should be the type of fabric designation, yet there is no y or p for that matter listed in the book
        the tape code is not even mentioned
        thgg= spring part #'s. the t seems to be a check digit, while the rest determine what you have
        h=d9ac-ha
        g=e5ac-ba
        i'll go through my 84 book to see if i can find more info for you
        Save a seal, club a liberal.
          still nothing abot the tape, and the spring codes were identical. the yp is still not listed but under type of material y is cloth with vinyl. and the p = sage.
          hope this helps. i lucked out on the other site a while back and got both the bce and powertrain manuals for crhristine and the shop manual for shifty. i guess at some point they combined the powertrain manual into the bce manual. there were two for christine and 1 manual for shifty. about 50 bux for the 3 of em roughly. i didn't order them at the same time because when i got the 84 manuals, i didn't have shifty. unfortunately, there was noting in either book to go over removing a fender . haynes and chilons are useless in this dept too. i found out the hard way lol trying to determine where every nut and bolt is
            Found the build sheet for my '88 tonight. It was under the drivers' seat. I figured I'd check the '91, too. Sure enough, build sheet was under the seat.
            Justin
