Belt problem
    Originally posted by 91waggin View Post
    I was told by a couple different people to steer clear of the leak sealers because it can clog orifice tubes. But if it works for you....
    It didn't seal the leak though, lol
    Originally posted by Mercracer View Post
    YOU just walked in and bought it? Sounds like you may have purchased R134 and your system may still be R12???????
    No, my systems an R134, the guy who owned it before me converted it. Btw how long does a recharge usually last?
    1986 Ford Crown Victoria Ltd
      untill it leaks out... so it depends how bad your leak is.
        Well, since it shouldn't leak, it ought to last indefinitely. Since this is the real world, I would not expect to recharge it more than once a year. If its leaking more than that, you have bigger problems that need to be fixed.
        You also have to be careful about doing an oil+refrigerant charge. The refrigerant leaks out a lot more than the oil. If you keep charging it with more oil, eventually you get a lot more in the system than should be in there. I'd strongly consider a full AC rebuild with a system flush. That way you'll have all new seals and know exactly how much oil is in there.
          Originally posted by lincolnmania View Post
          mang you got robbed......i would have replaced the hoses too for that much
          He did. I'm quite sure I didn't get robbed. I got several quotes and this guy wanted $795 plus tax (which in the great state of Washington comes to $860). The other places quoted me anywhere from $995 to $1300. This was two little guys doing a radiator and a/c service place from what was probably just a gas station 30-40 years ago. Anyway, they were very fast and very good and I will definitely go back there if the need arises. The place was A&B radiator on 4th Plain Rd. in Vancouver, WA.
