H.O. Cams
    you did get the ho upper and injectors ?
      yes i did also a 1/2 inch intake spacer for bigger valve covers because of the roller rocker arms. I'm going to grab a set of new pushrods as well from like napa or somthing as well as some new vacume lines well atleast to replace the broken ones i have...
      all i need now is the
      heads
      roller lifters
      roller rockers
      valve covers
      double roller timing set
      bored out lopo egr spacer
      i beleive thats it
      My old 87 Mercury Grand Marquis-RIP- http://www.cardomain.com/ride/3016650
      Now Driving A
      1999 Mercury Mountaineer with the 5.0 V8 its also AWD..... Atleast I'm keeping it in the Mercury family right?
        your car already has a speed sensor and roller lifters
          are you sure when i did the my valve cover gaskets those didn't look like any roller lifters i've ever seen
          Now Driving A
            Originally posted by Wray-Wray View Post
            this is mad bomb!!!!! i'm getting thew 88 roller cam shaft, H.O. throttle body, a 87 H.O. computer and a roller lifter convershion kit all for 150 shipped to me from this guys warehouse
            What Lincolnmania said. You don't need the roller conversion kit - you already have all the parts you need to use the E5 or E8 camshafts. Roller lifter tappets only need to be replaced if the rollers don't move freely, and the retaining bits don't have moving parts. I actually still have a $100 set of brand-new Summit roller lifters still sitting in their boxes because whilst swapping cams I determined I didn't need them.
            I'd also hold off on getting new pushrods and get a length-checking pushrod instead. Wouldn't want you to end up in the situation I have with my 306 and discover after the engine's assembled that you should have gotten rods that are slightly longer. Also, pushrods' only real wear point on a roller motor is at the tip where they contact the rocker arm, so they're usually reusable if the length is still correct.
            Are you getting pedestal-mount roller rockers or adjustable rockers with a stud kit?
              I hope you misspoke and said lifters instead of rockers ... the lifters live in the valley under the intake manifold and contact the camshaft directly. The only moving parts you see with just the valvecovers off are the pushrods, rockers, and valves.
                yes i ment to say rockers my mistake...i get words that sound alike mixed up...like my daughters names Keela and Aaliyah....i mix them up all the time....i get it from my mother...she will go threw all 4 of our names b4 she'd get the right one to yell @ my Father- Wray/ Me-Wray/ my Brother-Richard/ my Brother- Rory...itz all the r sounds... with the roller rockers and lifters itz the "ers" sound then gets me all messed up lol
                Now Driving A
                  :lol: Gotcha. Consider yourself un-admonished about spending unneeded cash on roller lifters. :p
                    haven't bought it yet
                    Now Driving A
                      The speed sensor is there if you have cruise. Its probably not your problem tho. I had the same crap, it was dirty contacts on the steering wheel slip ring. Scotchbrite on the contacts, contact cleaner in the switches and all is well. Steering wheel needs to come off for this.
                        i probably missed it i didn't bring a flashlight with me when i was under there...i'll keep that in mind although i don't use cruse control all that much anyways. i do have 2 odd little electrical problems with my car....
                        1.) my blickers can stop working but if i turn my hazzard lights on 4 a few blicks the signals work just fine...the flasher unit and the turn signal switch in the steering colum are both brand new like in feb this year... so im not exacly sure what is wrong...
                        2.) ever sence i replaced my 4 prong fuel relay with the 5 prong one i got from auto zone my car randomly stalls it startz up again with holding the starter on for a good 15 Mississippi count there is no pattern other than it does it when im slowing down or @ an idoal...it might do it once a day or once every week...its weird...im thinking take the relay out pray the relay with wd-40/brake cleaner/penetrating oil or something and spray the crap out of the connector...
                        Now Driving A
