Got the motor in the car and running....
    For those of you that have seen some of my post, I got the motor in the car and running.....
    Here are a couple of videos.
    Is that the EGR plug or the TPS connector that isn't plugged in? Sounds like you've got a little hesitation there. Whats the details on the engine ?
      looks like the egr plug.
        The EGR plug wasn't plugged in. Also, I don't have the o2 sensors plugged in either.
        That was just a test start to check oil pressure and to make sure it was going to fire.
        Specs...
        p/p h.o upper and lower
        p/p e7 heads
        H.o tb
        h.o cam advanced 4*
        24lb injectors
        255 lph intank pump
          Specs...
          p/p e7 heads
          H.o tb
          h.o cam advanced 4*
          24lb injectors
          255 lph intank pump
          ho lower is the same as the lopo.. what computer are you running?
          sounds pretty good, let us know how that cam advance works out for ya.
            A9L comp
              cool same one i got.. only problem i see is that computer isnt calibrated for 24lb injectors.
                why 24# injectors? They aren't necessary for that cam.
                  why the 24 lb injectors?
                  shit i got a few sets of them, never found any use for them yet
                    Only one car so far, Scott....
                    I agree, those 24s are a bit much, the car will run pretty darn rich. The fuel pump is an overkill too, and will just heat up the gas.
                    And a note for racing, the pickup location is high and centered, you will run out of gas on long turns if you run less than 1/4 tank. I've had issues autocrossing with 1/2 a tank.
                      I had the fuel pump and injectors in the garage from the stang. I figure this way it will never starve for fuel.
                      If it runs to ritch I will pull the injectors out and put a set of 19s in it.
                        As far as fuel.
                        I will fill it up before each race. The car is a tank any way so the weight isnt going to kill me.
                          That's a nice sounding machine you got there! Can't wait to see vids of that thing on the road.
                            Thanks Packman
                              wait.... you're running a MAF ECM with no MAF hooked up and not tuned for 24lb injectors, the EGR is unplugged and the o2 sensors are disconnected?
                              why?
