Intake manifold Studs
    Hi All,
    I'm going to remove my lower intake manifold to take care of an oil leak on my 1991 302 SEFI. While doing so, I will replace the hardware.
    My question is:
    I can't seem to find any specs on the intake studs (about six of them?) that are used with the intake bolts.
    The bolt size is 5/16"-18, and 2 inches long (I got them from Summit - #G1579). But they don't list the studs.
    Anybody have the info for the studs' length or type that I would need?
    Thanks in advance.
    There are no studs used. They are all bolts. There are a few that have small studs for mounting the ground wires and coolant pipes- but they are all bolts.
      they are all bolts.....some have threads for mounting accy bracket braces and ground wires
        Thanks, You're right.
        They actually are bolts, but with a threaded end on top to attach grounds and brackets.
        But, what do they call them? (I ask so i can search and order them from Summit, Jegs...)
          Is there some reason you can't just reuse the ones that you already have?
            I doubt anybody makes the exact ones. Might be able to get them from ford though.
              Wire wheel cleans them up good as new, I wouldnt waste my time getting new ones.
                Well, I broke the four corner bolts when removing my intake (used the torch/ vise grips to get the remnants). Suckers were stuck bad; I'd guess it was the first time the intake had been off. It was only the corner ones that gave me issues too; must've been that the water passages are there. But, since I have so many parts cars, I just borrowed a few bolts to reinstall the new intake.
                  That's what I'm worried about.
                  I took the driver-side one, near the firewall, to clean up the o2 sensor ground, and it looked pretty well corroded. I reattached the ground somewhere else and just put a new bolt in there.
                  ok, thanks fellas.
