Hey guys I just bought a Mark VIII fan for my Lincoln, and it has 3 wires coming out of the loom, 2 blacks and a blue. Does anyone know which is ground and which is power?
Mark VIII fan question
I think one has a light blue tracer on it if you can get back to clean wire. I forget which is which, mine I couldn't tell any difference, it moves silly amounts of air either way. ALl I can suggest is power it up and see what you can see.86 Lincoln Town Car (Galactica).
Originally posted by CheeseSteakJim View PostBlack is ground. The other two are the two different speeds, high and low. I forgot which was which. Put 'em to your battery and find out. I wired mine into low because even then it's more effective than most electric fans.
I wired up the Superlincoln to do that with a pair of relays. Its not really neccesary and the wiring is excessively complex. Honestly for multi-speed control I'd suggest one of those controllers that automatically varies the speed of the fan to control temperature.86 Lincoln Town Car (Galactica).
