Hola,
Did I search but didn't come up with an answer so hoping somebody can help me out. Will the factory pushrods work with GT40p heads and an explorer cam?
I also plan on putting a new timing chain on it. I know I should do new lifters and rockers. Who sells good factory replacements for lifters / rockers on the cheap? I'm about out of cashola and figured there is probably a good online source for factory replacment type parts... Or would it be worthwhile to step up to a 1.7 rocker, could it even be done economically?
Motor will be used for towing.
Thanks,
JD
Thanks,
JD
