the next problem:
i think the shift linkage is damaged somewhere.
its because when i turn the lever to P (and the lever is in the upperst position) the tranny is in reverse, when it is in R, the tranny is in Neutral and so on...
can it be, that the shift linkage has an adjustment screw or something like that...
the linkage itself is installed as before...
![Ugha](https://www.grandmarq.net/vb/core/images/smilies/ugha.gif)
