Ok I de-smogged my wagon last fall and have not worried about not having a belt running the a/c as I didnt need it, but now it is getting warmer and want to get it going again. What belt do I need for a car that has no smog pump at all?
What Belt?
560k6
take the tensioner pivot bolt out and put the belt on....then put the bolt back in......there is no longer belt
What he said. It goes, but its tight.86 Lincoln Town Car (Galactica).
I never had been able to make the short belt fit. I have found the later model belt tensioner, as well as the replacement tensioner pulley are larger, making it impossible to make the short belt fit.
I have found a 5 rib belt from the parts store that fits, but recently discovered the belt on the car has stretched and rubbing together once its tightened properly.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
My Dad helped me get the shorter one on like Scott said and it's been working well for a few months now.sigpic
1986 Grand Marquis LS 2 Door
get a tensioner with a smaller pulley.....all i can think of mang
Put it all back together and run a string around it all. A/C, belt tensioner, and crank pulley. Cut the string to fit and take it to the parts store. Get a belt the same size as the string and it should fit. That is if they make a 5 or 6 rib ( I forget if it is 5 or 6) belt that size.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
So did 90-91's have alittle different setup? I know that people have gotten this belt to work. Damn I wanted to have the A/C funtioning for my date tonight. Oh well so what if her hair gets fucked up. HAHAHa2000 Mustang GT "Blondie", 2000 CVPI "Sargent Crusty"
