my main driver (Sandy) my 1987 tan Grand Marq developed a bad oil leak and was wondering about time amount to repair. i know i am going to have to pull the plenum, but thinking i can unbolt the lower intake with fuel rail and lines connected still and lift out of the way. i am thinking the rear intake gasket blew out since it stated suddenly and under carriage of Sandy is now coated in rust protecting oil. i am trying to get an idea about time estimates by using just regular wrenches and ratchets and sockets. if needed, i will just pop the fuel rail off the intake with injectors. thanks for help in advance.
estimated time for intake gaskets
if i have to i will unbolt the fuel rail to get it out for proper cleaning. i have werked in a regular shop and watched the mechanic have a bungee hold the intake up while having a cover over the engine to keep debris out. guess this gives me reason to clean up the last H.O. plenum i have and paint to get installed.
Originally posted by mrltd View PostThe fuel line connector tools are a whopping 5-7 bucks to by and save a lot of headaches.
I'd say 6 hours to do it.
That's about right. I did mine, but took my sweet time with it. And that was with seperating everything. I took GUNK engine cleaner to the manifolds, and valve covers, and let them soak for a couple of hours, while I took care of everything under the hood. NOW is an excellent time to change out the PCV valve, and screen. Don't bother cleaning the old screen, for 6 bucks you can get a new one, and be done with it.
Mike
yeah its a decent day of work. Disconnect the fuel lines, you'll spend more time fighting with the fuel rail and hoping to not break it than its worth.86 Lincoln Town Car (Galactica).
A.K.A Kaptain Kanuck, Your Connection To The Great Land Of Eternal Winter and Incredibly Rusty Cars
- Oct 2006
- 2083
- Ontario
- Send PM
I just did mine, I'd say 5-6 hours. I dont know what the labour manual quotes. I couldnt imagine doing it with the fuel lines still attached. Cleaning off those old gaskets sucks hardcore, and its not something you can really half-ass. I'd say I put an hour into cleaning all the mating surfaces. Theres an eylet attached to a wire on the back left hand side of the manifold, and both lowers I've taken off I've had that eyelet break. And of the manifold bolts that have a stud on top of them (5 of them IIRC, 2 for the coolant tube on the right side of the motor, 2 for the braces for the acc brackets, and one on the back left hand side) will probably be rusted together, and will have to be seperated afterwards with pentrating fluid, a wrench and vicegrips. But then you gotta look at all the other stuff you might as well change while you have that much stuff un-bolted from the engine, like t-stat, t-stat housing gasket, pcv valve, grommet, filter, valve cover gaskets, plenum gasket, tv grommet. Pete made a tech article from all the stuff I posted when I did mine, and I have the torque specs for everything in there too, you have to torque the lower intake similar to torquing a cylinder head, and in two steps, and your supposed to re-torque it after a heat up and cool down cycle, which requires removing the upper again. Good luck Jim.sigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
And replace the thermostat while you've got the intake looking at you. Its so simple with it off its hard not to do it.86 Lincoln Town Car (Galactica).
Originally posted by PICKUP6772 View PostNOW is an excellent time to change out the PCV valve, and screen. Don't bother cleaning the old screen, for 6 bucks you can get a new one, and be done with it.
Mike'88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
'83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...
i ended up oredering in 5 of the PCV screens when i originally installed a screen in my car. that way i could have extras for the other Panthers here. i try to buy extra parts for the cars to have on hand here at home when money gets low. i was never a Boyscout, yet when it comes to these cars, i try to be prepared. IIRC i think i have a full timing gear set, timing chain cover gasket and intake gasket set still in the trunk of one of the cars. it gets hard to keep track of the extra parts i have that i get.
Originally posted by 91LTDProject View PostI just did mine, I'd say 5-6 hours. I dont know what the labour manual quotes. I couldnt imagine doing it with the fuel lines still attached. Cleaning off those old gaskets sucks hardcore, and its not something you can really half-ass. I'd say I put an hour into cleaning all the mating surfaces. Theres an eylet attached to a wire on the back left hand side of the manifold, and both lowers I've taken off I've had that eyelet break. And of the manifold bolts that have a stud on top of them (5 of them IIRC, 2 for the coolant tube on the right side of the motor, 2 for the braces for the acc brackets, and one on the back left hand side) will probably be rusted together, and will have to be seperated afterwards with pentrating fluid, a wrench and vicegrips. But then you gotta look at all the other stuff you might as well change while you have that much stuff un-bolted from the engine, like t-stat, t-stat housing gasket, pcv valve, grommet, filter, valve cover gaskets, plenum gasket, tv grommet. Pete made a tech article from all the stuff I posted when I did mine, and I have the torque specs for everything in there too, you have to torque the lower intake similar to torquing a cylinder head, and in two steps, and your supposed to re-torque it after a heat up and cool down cycle, which requires removing the upper again. Good luck Jim.
