Idle and cruise control probs
    Alright this time I let it run for atleast a minute and the CEL never game on. With the engine off but key in ON position, the CEL stayed on solid and never blinked. I left it on for atleast a minute. oh yeah, and I bypassed the plugs and hard wired the two wires together so I KNOW they're getting signal.
    Funny thing... I just called the AZ I went to 5 mins ago and asked if they did OBD1 and the same lady said "The guy that can do it comes in at 2". I almost fucking smacked her through the phone. Why couldn't she have told me that when I walked in?
    \'05 Suzuki GSX-R - Daily Driver
    \'87 Ford Crown Vic Country Squire - Sad to see her go
    \'87 Mazda RX-7 - 302 project
    Yeah.... it\'s stock. =)
      like i said, all depends on who you talk to, or when you talk to them.
      Save a seal, club a liberal.
        OKIE DOKIE NOW we're getting somewhere... never was able to pull it myself. Ended up at AZ again and they finally did it after 20 mins of waiting.
        It's a code 34.
        34 EVP - (R) EGR did not respond properly during test - EVP
        EVR - (O, R, M) EVP sensor is/was high - EVR
        PFE - (O, R, M) PFE sensor is/was out of range - PFE
        So this would be the EGR valve? If it is, anyone care to let me know where it is so I can put off buying the $25 haynes manual another few days? lol
          #34?!??!??!?! OMG send that rust-wagon to Copher's
          grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
          there, now im cool too
              haha you know i like your wagon. its neato. but you just wait til the GMGT conversion is complete, with the HO, bitch.
                Very likely stuck egr valve. Pull it and see if its frozen up or jammed with carbon.
                  ouch.... $75 for a new egr valve. Haven't gotten it yet though. I did push the rod in and out and it wasn't jammed. I did clean it all out with carb cleaner. Of course it made no difference.
                    Hey ok well idle problem fixed... (Credit to Jason91gm) He pulled the vaccum line off the EGR valve and it now idles perfectly again.
                    But what about the cruise control? It's still acting up. The VSS connection looks fine. Is there a way I can test the sensor? Like maybe the output voltage from the VSS to wherever it goes or what?
                      EGR itself is good then, but the EVP solenoid is shot or something. That should be over on the fenderwell. The filter for those also gets clogged, which might be the problem.
                      No idea how to test that VSS sensor. I'm sure its possible somehow tho.
