dont waste your time bolting parts to a 270,000km shortblock......start out with a 94-97 351w shortblock....why? because it has a roller cam......not tearing your ride apart, you can drive the car while you get the block done and gather other goodies.....puttin a new top end and just bearings is just asjing for trouble if you ask me....one speck of grit can wipe out a bearing.....do it right the first time instead of cobbling some new parts together on a low compresssion tired out cop car motor with cast pistons.....you said you want to use nitrous.....should have at least hypereutectic pistons if you are going to give it laughing gas.
heads
Screw Hypereutectic and screw 351 cubes....
Coast High Perfromance
Cast Steel 3.850 Stroke Crankshaft
5.956 CHP "Race Ready" press fit connecting rods
Probe Industries FPS Series forged pistons (dish top)
Std-.030-.040-.060 bore sizes
10.0:1 (w/61cc head and .015 deck) (-12.2cc dish)
Fits any cylinder head (except Edelbrock Victor)
Moly ring set
Clevitte rod and main bearings
Part Number 9601-14033
Reduced $150.00! Only $949.99
1st thing that should be decided is what you want for power..then decide.
if you're looking for say...220hp, a full HO conversion would be in order.
Summit makes a good version of the shorty headers...just liek the FRFF ones..but in ceramic coated, WAY cheaper....like 240bux.
E7TE heads can be picked up real cheap..check out mustang forums like corral.net...or Ebay....see if anyone in the area is selling them dirt cheap...like 50bux each and then you could have them cleaned up and ported and make some great power.
such as...it cost me a total of about 800bux to have Turbo's buddy clean up/revalve/port a set of E7TEs...money well spent!
here's how they looked after they were done...I coudl have eaten off the darn things. lol
Originally posted by chris_russell11_13 View Posti have an 85 cv. its carbed. totally stock. im wanting to put in a 4 bbl car, intake, heads, cam, headers, exhaust, and maybe nitrous. probably some other stuff too as i get ideas. it has about 270 000 kms on it. i need to replace the main bearings, but i want to rebuild the engine eventually. i want to put gears and do some stuff to the tranny too.
Get back to us afterwards, there is no point in tossing anything on it until then.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by Mr. Land Yacht View Postif you're looking for say...220hp, a full HO conversion would be in order.
Originally posted by Nathan in MN View PostAn HO conversion on a 351W?
Ford even stuck the HO label on a 351C 4V motor in 1972. It was a low compression open combustion chamber version of the Boss 351. It performed poorly in direct comparison to the Boss.
Even recent vintage roller cam 351s in stock truck form are kind of pitiful. Not much more perk than a 302 in the same vehicle, and they suck more fuel.86 Lincoln Town Car (Galactica).
Originally posted by chris_russell11_13 View Postif i use a block from those years doesnt that mean i will have to make it fuel injected?Builder/Owner of Badass Panther Wagons
no.....it just means you can use a roller cam. use whatever induction you want carb or efi
Only if you use the linkbar conversion roller lifters. They're around 500 bucks or more a set.
You'd be far better off either with a factory roller cam compatible block, or simply using a flat tappet camshaft.Last edited by gadget73; 05-07-2008, 02:46 AM.86 Lincoln Town Car (Galactica).
You'd be better off starting with a good condition shortblock, then select a set of heads that compliments the cam and intake choice. Those will depend on what you want to do with the car.86 Lincoln Town Car (Galactica).
