heads
    ok thanks. were can i find a set of new gt 40 heads? is ford racing the only place to get them?
      Buy a complete Explorer motor.....
      The Iron GT40 heads are no longer available from FRPP....
        so just try and find a 5 liter explorer engine from a salvage yard?
          Find a 1996 for the GT40 heads. Some early 1997 motors were GT40 before the switch to GT40P. If you look at the ends of the heads, a GT40 head has 3 vertical bars and a GT40P has 4. On the exhaust side of the head there will also be either a GT or a GTP cast into them.
            I would go with the GT40X heads. Think there like 170cc's
              If you go with JY GT40p's make sure to get new valve springs. Its a good idea to have a machine shop check em out and rebuild em and throw the new springs in at the same time. That way you got a set of fresh heads and the valves wont float at 4800prm
                FYIthat applies to ALL GT40s- spring wise.. Junkyard or not.
                  Just a quick FYI - If you are looking for a good deal on GT40's, check out the National Lightning Owners Club www.nloc.net in the 'Gen1' parts section, they always have sets going up for sale.
                  https://www.facebook.com/jason.baker.1614
                  1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
                  1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
                  2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
                  2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
                    Or corral.net... decent ones can be had for less than 400 bucks...
                      where would i find an explorer motor, and roughly how much would it cost?
                      and i have a dumb question .... whats frpp stand for?
                        1. your local junk yard/anywhere you can aquire used engines. Depending on the yard and condition..$300-800
                        2. Ford Racing Performance Parts
                          i just checked on fordracing.com and they have gt40x heads. they are alluminum, would they be worth it or should i just get the explorer motor?
                            Short answer.... If you can afford aluminum heads, don't bother with iron heads. You can probably find TFS TW heads for the price of GT40X heads
                              hey, im pretty much redoing the air flow system of my 85 vic. i was wondering what heads would be better than stock. and i would need part numbers too.
                              Having read through the entire thread here, I wonder if you have researched this idea thoroughly. I honestly don't wish to sound demeaning, but we have absolutely zero information about the current setup in the car (engine size? I think I saw something about a 351W), the mileage on the engine, how fast you want the car to be, etc. As a result, the advice being offered is jumping back and forth, as we get not even the most basic of information about the car. Hell, it may even be that the car's engine isn't worth modifying due to excessive mileage, setup (302 CFI? 351W carbed?)....there are plenty of intelligent guys who love to help here, however, I would recommend getting us as much information as you can....otherwise...
                                i have an 85 cv. its carbed. totally stock. im wanting to put in a 4 bbl car, intake, heads, cam, headers, exhaust, and maybe nitrous. probably some other stuff too as i get ideas. it has about 270 000 kms on it. i need to replace the main bearings, but i want to rebuild the engine eventually. i want to put gears and do some stuff to the tranny too.
