Idle problems
    Idle problems
    this morning i start up my car and it starts and it was idling at like 300 rpm but yesterday it ran fine. It would rev up just fine but it would still idle like shit.
    What would cause this?
    change in weather......is it ok after its warmed up and driven a bit?
    could try cleaning the idle air control valve it might be sticky
      CFI mang
      Sounds like the choke didn't come on. Did you set the choke by pumping the gas once before you started it? Did it run fine once it was warm?
        What year car do you have? Would be of great help if you put that in your sig, things are different year to year.
          His car is an '85 I believe.
            yeah its an 85 and yeah i pumped the gas.
            Where is the iac valve located?
              there is no spoon......sorry thought u had an 86 or a 87
                i just had it warmed up and it seemed to idle alright. And what would it be if it doesnt have this spoon?
                  CFI cars use a throttle kicker and a high idle cam operated off a choke coil. If the high idle linkage is sticky, it won't flip down to keep the idle up as the engine warms. Basically if you happen to know anything about carb choke systems, you can figure out a CFI unit. Same sort of choke setup.
                    so if I lube all of that up itd be ok?
                      If thats the problem. Probably want to use carb cleaner to dissolve any gunk thats built up.
                        ok thanks
