Today my 91 GM experienced a tranny problem. It is not shifting properly. Only after the revs are high will it shift gears but really clunks into gear. The fluid is good and clean. Just had a service a few months ago. Am I looking at a major repair here or would it be just an adjustment? Thanks for your input...
Tranny trouble
Tranny trouble
1991 Grey Grand Marquis LS Sedan
61,000 Miles
1998 F150 XLT 4X2 Flareside Fire Engine Red
52,000 Miles
http://www.cardomain.com/id/hdlogisticsTags: None
The AOD trans doesn't have a vacuum modulator like the old C4 and C6 tranny has.86 Lincoln Town Car (Galactica).
dont drive it till you make sure that the tv cable is hooked to the gromnet on the throttle body.......good possibility it fell off which could lead to disaster if not fixed
The tv cable did brake off and got jammed. As soon as I knew there was a problem, I parked the car at home. My friend is going to replace the tv cable for me in the next few days. I didn't have to drive very far to get home so I'm hoping there is no more unseen damage. Thanks for your help guy's. H.1991 Grey Grand Marquis LS Sedan
61,000 Miles
52,000 Miles
replace the gromnet also......they get hard and brittle from the heat, the #1 cause of aod failure
scott
I did replace the grommet with a brass one a while back and the cable looked ok then but with a 14 year old box I guess you have to expect a lot of ware.1991 Grey Grand Marquis LS Sedan
61,000 Miles
52,000 Miles
