Timing cover gasket installation ?'s
    Well, I only really have one. Using the felpro set (blue gaskets) and was wondering if you install the gaskets dry between the timing cover and the block (using a spray adhesive to hold in place) or should I run a bead of RTV around then put it together. The directions with the gasketset are rather vague...
    i smear ultra black on both sides of the gasket.
      Thanks scott. Now I go back to work to get the bolts I forgot to so I can install the damn cover.
