i swithed mine to carb from cfi heres some pics from that and other stuff i just did. i put a 130 amp alt with a 130 fuse block in it so it could support my subs and my screen as you can see. if you can see in the pic with the foot my alarm key chain that was a pain to put in. the side exhaust with the shorty headers and glass packs with 2.5 inch pipe. The sad part is my subs are bigger then my rims lol. i'm looking for some nice used mustang rims like 17s or 18s if any one has some.
my carb converson and more
---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
---1985 Grand Marquis 2-door., Fresh 5.0, slick-top, GT40P's, 1.7 RR's, FRPP headers, 3G alt., Weiand Stealth intake, 650 cfm holley, 2.5" side-exit exhaust, Mark 8 elec. fan, 3:55 Posi, Bucket seats, custom center console. My ToyTags: None
Looks good. I see you used a TV cable too (yours came with a rod, correct?). Is the cable from an EFI car or something else?1990 Country Squire - under restoration
Sweet! What'd you use for a grommet to hold the TV cable to the carb throttle arm?**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
oohh.... very nice
looks like great work - and yes more info on your throttle/kickdown setup will be helpfull. It looks like mostly the original stuff, yes?Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Whats that throttle cable bracket from? WOuld be awful nice to be able to use stock EFI cables on a carb swap.
Also, you planning to lower the car or anything? Back tires look a bit small in there.86 Lincoln Town Car (Galactica).
mustang wheels wont work without spacers. check the stickies in the suspension forumhttp://secondhandracing.com/Home.aspx
yes mine originally had the rod type. i pulled the block type tv cable and the arm it connects to on the trans from i believe a 89/90 5.0L EFI. i made my own custom brackets to hold it in place on the intake and on the trans. plus i had to do some mods on the trans lever to get it to work around the shifting linkage. on the gommet mine has a plastic one and the tv is held inplace with a locking C clip.Last edited by Bowman85merc; 03-17-2008, 09:13 PM.---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
ya my tires are only 205/70/14s alll the way around and my subs are 15's its kinda sad but i don't have much money left to spend on it so i'm trying to find some used rims---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
i was going to use an offy 360 degree intake but i think i made the beter choise and just spent 200 on the one thats on it---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
ya that would be nice but i want to see a 2 door with no top to see what it looks like. and what they did with the lights on the side---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
Originally posted by Bowman85merc View Postya that would be nice but i want to see a 2 door with no top to see what it looks like. and what they did with the lights on the side
There's an '81 Tudor slicktop from the 1981 LTD broshure. To look right, I think you'll need the rear side window trim from a Ford tudor.1990 Country Squire - under restoration
that is fuckin ugly, sorry. Get the top redone.86 Lincoln Town Car (Galactica).
Which Weiand intake is that, the Stealth? Are they cam and heads still stock at present?
14" rims aren't so bad with some taller tires. Too bad 225/75/14s are so hard to find these days.2012 Mazda5 Touring | Finally working on the LTD again!
ya the cam and heads are stock i had to replace the timming chain when i put the intake on so i'm kicking my self in the ass for not putting a cam in it then---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
