New Fuel Pump
    New Fuel Pump
    Can I make this fuel pump work for my car http://store.summitracing.com/partde...5&autoview=sku
    i take it you got EFI/CFI, with mods it will work, but not nessasary for stock 5.0L
      Maybe. That's what the rest of us use for pump upgrades. Should be quite a few threads on it.
        yes, but the 155 lph one is cheaper and more than enough for your needs. More than enough for an HO or even somewhat beyond that point.
          I'm running a 110 in my wagon... Does fine.
            i install mustang 155 lph pumps......summit has em cheap......requires minor mods
              what are these minor mods again
                need a 1 foot piece of EFI fuel hose, a hose clamp, and a knife. Slide the pump into the rubber sock, put a slice on each side of the rubber sock. Feed the hose clamp through it, and snug it down to keep the fuel pump in position. Install the fuel sock, hook up the wires. replace the stock piece of fuel hose from the metal hanger to the pump with the new longer piece. cut it to fit as needed.
