after my car heats up and and am stopped in drive my engine light flickers on and off and sometimes just stays on solid. but once i start moving or put it in park the light goes out. is that anything to worry about?
engine light
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Oil pressure is getting low...very typical with these cars after 20 years or so. What weight of oil are you running? Best bet is to put a little bit heavier oil in it and keep driving.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Is the light still coming on with the 10W30? It's not a huge concern; you'd be surprised how well a small block Ford can run with virtually no oil pressure. Just ask Mike (Mr. LTD) about his old '87 Crown Vic.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
No, he's not overheating it. The oil warms up and thins out, and the oil pressure drops off. Completely, utterly normal under those conditions.
dead bearings. typical problem. keep driving.86 Lincoln Town Car (Galactica).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Depends on how bad they are. If they get loose enough, they'll start to knock, but they can be loose to the point of low oil pressure without making any noises.
Originally posted by chris_russell11_13 View Postany idea on how much a rebuild would cost?2012 Mazda5 Touring | Finally working on the LTD again!
My machine shop bill was close to 700, and the engine kit about another 300. Could have gotten it a bit cheaper if I'd ordered it direct but I got it through the machine shop. I'm guessing like 1200-1300 all told after the misc items, paint, oil drain plugs, spark plugs, wires, cap, rotor, yadda yadda yadda. If you're paying someone to assemble it, its going to be a fair bit more.86 Lincoln Town Car (Galactica).
