I am wondering what would be better to do. Should i spend the money and get the parts and convert my 1989 Grand Marquis to the HO motor or pick up a carborated 351 and do a good cam and intake and port the heads. If i go with the 351 can i use my 5.0 flywheel and starter along with my water pump and serpentine accessories and brackets.
5.0HO or 351W
There's no replacement for displacement. However, the HO swap for your car is a tried and trued way to increase power and economy without even having to pull the motor. Being 351 equipped myself, I am biased toward the larger displacement, however the HO swap will be cheaper, and a whole lot easier. BTW,
with the 351, all your accessories will work, however if you want to run AC you will need a specific ac bracket. the alternator bracket is the same, just use different holes.
you will need a 28 oz. imbalance flexplate, the starter is the same. some where here (i think it might be in the tech archives) i have a thread covering a 351 swaphttp://secondhandracing.com/Home.aspx
