Yep, been posted and discussed before. I don't think I'd do this mod as it apparently somehow removes engine braking in 2nd gear, and I like having engine braking.
I use manual 3 a lot more than I would ever use manual 2. Losing that ability would annoy me. I'd much rather have it modded so overdrive lockout was electronic via a button or something like the electronic trannys have. Apparently that does exist somehow but its spendy.
Unless it's purely for drag racing, it's not worth doing. I had one for a while and manual 2 was pretty useless for anything. I spent the entire year wishing I had manual 3rd.
