The '80 is Not starting again
    thats exactly what the stang is doing. and it has a new holley 600 4barrel on it. the damn thing ran so good and one morning no go. it seems like quick start makes it kick over better.
      every time i use the quick start it makes worse,, weird
        i wonder if its gots somethin to do with the timing chain. does it have a crunching sound commin from the front of the motor when cranking it?
          no not that i can hear, i just know that when it does run its got a hell of a knock, on account of the spun bearing, i just need it to run so i can move it easyer, till i can get it in the garage, and pull the motor for rebuild
            My car would do that for either two things: 1) when the timing was way off. It would sound just like that. Check to see if your distributor is tight and not moving, if it's tight that timing chain or gears are shit and it will keep jump timing.
            2) when it was out of fuel. Try spraying some starter fluid in the carb and see if it starts.
              I'd also say timing off and possibly flooded. If its real cold and you have the original plastic timing set, they have been known to just jump like that. The chain gets stretched out, cam is hard to turn, and it hops over and wont fire any more. Might be able to jockey the distributor around to make it run. They will run a tooth off but it wont be ideal, but you will have to bring the ignition timing back to where it belongs. Actually if you want to do a quick check on that theory, hook a timing light up and see if the marks line up properly. If the timing chain or something else moved, you'll see the timing marks not lining up with the pointer properly.
                i may try to advance the timming a bit tomorow and see if it makes a difference
                  The F-100 wouldn't start today, it would do something like your LTD was doing. I got it started by spraying starter fluid in it. I could smell gas, but it wouldn't start. Sprayed it in the carb and it started right up if you still can't get it to start, you could try that.
                    well i changed all the plugs today and she fired up up first click, runs good aside from the bearing being fucked
                      Hmm thats weired, the plugs didn't look that bad. Someone at work tole me if you flood the motor it will wreck the spark plugs. Once the electrodes get soaked with gas they are fucked. Is this true?
                        Get a timing light and check the timing.
                          hmmmm, might have to see if that works on buddies stang.
                            yea its a shame i have to pull the motor cuz ut starts and runs so good now, and no smoke eather, but oh well, she will be even better when it rebuilt
                            oh yea i forgot to mention, one of the old spark plugs was bearly even bolted in to the head
                              hey, it will be well worth it!
                                oh yea, i dont relly have a choice in the matter since the bearing is totaly shot, and the rear oil seal leaks pretty bad
