Yep, just what I needed in the middle of winter. Got home from work and checked the transmission fluid ... it was good to go. For some reason, I pulled the oil dipstick and was met with a continuous cloud of smoke. Milky substance all the way to the top of the dipstick, too. Smoke also comes out of the oil filler tube.
Car runs smooth, but has had idle issues for about three months, now. Has been slowly increasing it's coolant consumption over the past two months. Radiator was pretty empty a couple weeks ago. Engine does not overheat. Have only been driving to and from work with the car (3.5 miles one-way at 25 mph or so). Had found a small amount of milky substance on the tip of the dipstick the past couple of times when checking the oil cold.
Due to the cold weather, it's just going to have to be parked. I'll start with a visual inspection, then pull it apart. I just hope it's not head gaskets. I'm open to any advice or tips on this subject.
I'll keep you guys posted as to what comes of all this, but it may be a while.
