i got a set of 92 upper control arms today (the only 96+ spindles i could find were seized), just wondering how you remove the bushings off the arm i was using a hammer to hit the crossbar and push the bushings out and i succeded in fucking up the threads on the crossbar. I can either try to fix the threads on these or can i use the crossbars off of my 85.
brake upgrade
brake upgrade
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
