Ive got a ford crate 302 when ever i rev it up quickly it wants to backfire though the intake. Ive tried the timing every where it would run, tuned the float levels and idle screws on the carb(holley 600). The only way I got it to stop was to take off the vacuum adv. and wire the choke most of the way closed- not what I want to do! Do yall have any Ideers?
Backfiring 302
Backfiring 302
1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
sigpicTags: None
Do you know for a fact the carb is good? Its not some random used thing from a box o parts or something right? Fuel pressure OK? It sounds lean to me, either a vacuum leak, poor pressure, or some internal issue with the carb. Not enough / non-working acceleratir pump can also do this. Holleys have an adjustable pump shot, if thats way lean or if the linkage is not working somehow it would make it pop and splutter when revving.86 Lincoln Town Car (Galactica).
I just rebuilt the carb yesterday, it was doing it before I did so it wasn't something I messed up. Ive ajusted the mixture screws and the linkage on the accelerator pump none of that seem to make a difference in the backfiring. Ill hook up a vacuum gauge tomorrow to see what it reads. Thanks for the idea.
Any others?1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
does the accel pump actually squirt fuel when you open the throttle blades up? There aren't any un-used vacuum ports on the carb right? Does the idle change if you spray carb cleaner or whatever around the base of the carb or along the edge of the intake near the head?86 Lincoln Town Car (Galactica).
Ok I check the compression on all cylinders and it was 150 +- 5 all the way around. The vacuum was around 15-18 at idle steady would drop to near zero when you blip the throttle and rise then steady out if you hold it at rpm. The carb does squirt fuel in when you hit the throttle. I tried spraying carb cleaner around and noticed no difference. I went ahead and change plugs/wires/points - no difference. It makes good power after it backfires a couple times. I'm so out of ideas you all have any others? I welcome and appreciate all input no matter how obvious it is.
Thank you!1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
i'm really no carb guru, thats just the things that i could think of. The accel pump squirts as soon as you start to open the throttle right, no dead spots or anything? It sounds to me like it needs more pump but I'm not familiar enough with Holley carbs to tell you how to do that exactly. If it was an Edelbrock or Quadrajet, those use holes in the rocker arm, just change where the link goes. I dont think the Holley uses that setup though.86 Lincoln Town Car (Galactica).
Yes I've triple checked the firing order I even tried the H.O. order for shits and giggles.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Its defiantly not the HO firing order it doesn't miss constantly enough and when I tried the ho order it ran like shit. Ive step up the shot in to the carb and it help but didn't eliminate the problem. What are the primary rods and how do I change them?1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
