Stock Box Radiator Dimensions.
    Like the title says......does anybody know this? I would go out there and measure it myself, but it is pouring outside and won't clear up 'til the morning. I am also wondering how the aftermarket radiator companies measure their stuff. I would guess from tank to tank in width and from the bottom of one tank to the top of the same tank. I would like to see if I can get an aftermarket unit that comes close to our box radiators.
    kinda been wondering about aftermarket rads meself
      Doesn't Blaze have an aftermarket radiator from Griffin or BeCool or someone?
        I think he got a radiator from Summit. I took some rough measurements of the box radiator. 33-1/2" W x 20" H x 2-1/3" D (the tanks). I'll look at and contact the aftermarket radiator companies to see if they have any that come close to those measurements. Then I'll see which electric fan I can get to fit on whatever radiator I get. Again, I am trying to do as much research as possible to minimize down time on this car when I start really modding it.
          The inlet on box radiators (5.0L) is on the passenger's side and the outlet is on the driver's side, right?
            Right.
              Cool, thanks!!!
                Get a 31 x 19. Radiator companies measure overall, our factory rad is 31"tank so the aftermarket will be a little smaller, but you just need to relocate your driverside upper mount over. It is pretty easy.
                I'm running a 31 x 19 griffen sportsman, it cools my motor fine with a big and a small electric fan.
                You can get a radiator from either summit of speedway. I paid $160 for mine, a stock replacement runs like $200+
                  Funny, I paid somewhat less than that for the stock replacement I bought new. Granted, that was about 7 years ago.... I like the price on yours; does it include a tranny cooler, or do you have to run that separately?
                    That's the radiator that Griffin suggested I go with, probably because that is the largest one that they have. I figure with a big electric fan, tranny cooler, and possibly an electric water pump, I should be able to keep whatever modded engine I build relatively cool.
                      No it does not come with a tranny cooler, and I would not use it anyway. Just the 8-pass tube and fin cooler kept my tranny cool enough, with the additional 6-pass it keeps it at 150-180, that's with a C4 that holds 8qts and a 10" 2600 stall converter
                        Somewhat unrelated - is that the converter with the smaller flexplate bolt pattern that's used with a 157-tooth flexplate?
                          I got a Derale (I think that is the name) unit that I used on the Malibu, I figured that I can get better use out of it rather than it sitting in my basement.
                            Nope I'm using 164 tooth aod size flexplate, the converter I have is kinda custom since TCI does not list it. It is a big bell, pan fill, 28-spline, street fighter with a anti-baloon plate, the two similar that they list are priced about $670 or so, I paid $440 brand new, but I paid $100 each for two refurbished bell housings
