Originally posted by 1987cp
View Post
Smog pump
could it work either way???
I have the grooves on the tensioner to run just the smog pump on the 85. So far so good.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by Glen View PostI know it has been asked many times before, but I will ask again, What is the belt number that you use after the pump is gone? My AC works so I need the belt to run it too.
56 inch, 6 rib belt
yeah, bound to get more belt life out of it the correct way.
I was actually expecting mine to squeal or make ruckus but so far so good.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by FatNasty View Post560k6
56 inch, 6 rib belt
