Ok just found out My power steering pump is leaking it is the original one. I have 2 questions can the cold make the seals on the pump dry out? it was in the single digits in mi this past weekend. can the shaft seal the one behind the pulley be replaced? or should I get a new pump? How much are they? thanks mangs
power steering pump Question's
the rubber could shrink in the cold, but if it shrunk enough to leak, its probably toast. The seal is replaceable but its probably as much or more work to actually do it vs replacing the whole pump. If its the original pump, its had a good life.86 Lincoln Town Car (Galactica).
thain are there two different high pressure hoses? since mines a towing pk car? yeah my pump is the original
no, high pressure line is the same. the low pressure stuff is different, but its just bulk hosse.86 Lincoln Town Car (Galactica).
Originally posted by gabegt90 View PostOk just found out My power steering pump is leaking it is the original one. I have 2 questions can the cold make the seals on the pump dry out? it was in the single digits in mi this past weekend. can the shaft seal the one behind the pulley be replaced? or should I get a new pump? How much are they? thanks mangsLast edited by Mercracer; 01-25-2008, 08:07 PM.
I got the pump I just forgot to get the puller tools lol
you'll have to take the bracket with you if you do that, but its only a couple bolts. alternator comes off, then i think there are 2 bolts through the top of it into the head, and 3 nuts on the water pump or something. good excuse to clean up that bracket anyway, usually they're nasty.86 Lincoln Town Car (Galactica).
Saginaw? Isn't that the GM PS stuff?86 Lincoln Town Car (Galactica).
yeps, truck guys love it cause unlike the plastic-tank stocker tis pretty strong and also has no retarded leaks between the tank and the rest. Normally some fabrication is involved so it lines up with on a Ford engine, but A1 now makes Saginaw pumps with the Ford bracketry.
Originally posted by Mercracer View PostThe best bet is to bring your old pump in for the core and switch them over right there in the parts store. That way you turn 2 trips into 1.2012 Mazda5 Touring | Finally working on the LTD again!
