what next
    3L55 88 6G15
    This particular one means:
    3.55 limited slip, 8.8" carrier, assembly date July 15, 1986 (incidentally my bday is July 15).
    Wouldn't 6 be June, rather than July?
      actually G is july 6 is 1986.
        Ah, okay. Learn something new every day!
          don't ask me where the decade is, I just know its the original axle under my 1986, so the numbers jive pretty well. I think the production date on my car's door sticker says 7/86 so it must be a mid-late July car if the rear was built on the 15th. I found the date code stuff here:
          normally there would be some engineering number that I guess you could base the decade off of, but I dont know where that number happens to be on the axle housing. I'm sure its somewhere but I dont care enough to look. Probably E2 or E3 or something.
