what next
    yea thats the only thing i dont like that is how the coil is one the dist.
    ---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
    ---1985 Grand Marquis 2-door., Fresh 5.0, slick-top, GT40P's, 1.7 RR's, FRPP headers, 3G alt., Weiand Stealth intake, 650 cfm holley, 2.5" side-exit exhaust, Mark 8 elec. fan, 3:55 Posi, Bucket seats, custom center console. My Toy
      this is not off of a GM this is brand new off of ebay so i just bought it it was like 65 with shipping
        GM HEI does have a module, but its inside the distributor itself. Only thing you hook up is power and wire to a tach if you want it. It might not be the absolute cat's ass for super high power motors, but on something thats close to stock, it works just fine.
        Not sure about just using a T in the line. It might work but there's no way to regulate pressure. A return style regulator would be a better option instead of the tee, or even a dead-head regulator between the tee and the carb to ensure your fuel pressure is not too high.
          yea a guy said to put a regulator on it and make it between 5-7 psi of pressure if i recall
            5-7 is about right, depends on the specific carb you're using. some want a little less. that info will be in the manual for the carb.
              Is the "cat's a**" similar to the "bee's knees"?
                the intake im using is an offenhauser mid-rise with a 600 holley 80457... and i wanted to put a 1'' spacer on it...how much would i have to regulate that or would u know ???
                  Which Offy are you using? I tried a divided single-plane on my car and it really didn't work that well, even with a 1" four-hole carb spacer. Part of it is that my stock GT40 heads just don't flow that much. I swapped on a Performer 289 and it's making more power across the board, especially on a motor that has to operate below 2 grand (lockup torque converter) and never sees the high side of 5500rpm.
                  Edelbrock carbs like to see 5-6psi, which with my stock replacement mechanical pump requires no regulator. Seems I've read that some Holley applications may like to see 7 or even 8 - check the manufacturer's recommendations for your particular model.
                    yea the offy i have is a 360 degree one which i bet is the same one ur talkin about basically, mine is a dual plane...but it didnt work that well for you ???
                      Is it the one with wide-open plenum with a divider down the middle, or the Dual Port with dividers in the middle of each outlet? The former is what I tried, looks basically kind of like a Victor Jr. but with a wall in the middle. Frustratingly, the swap-meet guy I bought it from claimed it'd perform more like a Performer than a Performer RPM ... WRONG!
                      Anyway, the Dual Port is supposed to be fantastic for low end ... I wish I'd been able to find one for my other motor that has to deal with even lower RPMs. Then there's the Port-O-Sonic, a wide-open single plane, but I doubt you're talking about that one. The two I mentioned to start with are both marked "360 degree" and not much else, you have to look at the plenum/passages to ID them.
                      Have you decided what cam and heads you're using?
                        quite similar indeed. something could in fact be the bee's knees, the cat's ass, and the dog's bollocks all at the same time, but only if it were truly a fine thing.
                          i still say if the cfi car runs good, leave it be........regis's 85 runs like brandy new, and so does fairplays 85.......one of these days i'm gonna do a cfi ho from a mk7 hehe
                            yea my dad says we should leave it because it runs just fine, but i want to have more power lol...but my intake has the wall in the middle...and the cam i wanna use smeday is this http://cgi.ebay.com/ebaymotors/COMP-...QQcmdZViewItem
                              Link no work .... got a link for it on Summit Racing, or better yet, a manufacturer's part number?
                                oops my bad sorry heres the number that u put into ebay... 150207316927 ...it has everything i want and basically need and everything is matched to everything...do any of u think its a good idea lol
