Cam/Lifter Install 50% Finished
    This little ordeal should've already been done/over, but as I have no garage, really good tools, etc.....oh well, at least its almost finished....
    sigpic1991 Crown Vic 351w 5.8L
      Originally posted by Mercmarquis View Post
      Unbolt rockers, take out pushrods, remove intake, pull lifters out. Usually you need pliers, dont pull straight out but wiggle em back and forth. Pop new (heavily coated with cam lube) lifters in and go.
      hydraulic flat tappet lifters be pretty cheap too....I remember you saying you had lifter noise, Sooo might not be too hard or expensive to fix.
      sweet. I havent taken an engine down that far, as you can tell.
      Id have to pull the intake off to see if I have a roller block or not... the donor block was an 86, but I dont know if it was rebiult with 85 stuff or not...
        Mangs, I got the head (No pun intended) back from the machine shop today, got a new double roller timing chain/gasket set, so all thats left is get the center head gasket and a new set of head gaskets....Todays cost was:
        Timing Chain w/ new gears and Timing chain gasket-$38
        Machine Shop Costs-$20
        __________________________
        Total-$58
        Not bad, but just need a little more, an the vic will be resurrected (A 2nd Time) By now I am sure the Panther Gods are shaking their heads.....
            Dear lord above Nathan, the Gasket BETWEEN the heads, hence CENTER of the heads gasket....jeez
              Theres hostility between these two... SECURITY...
                Hey, I may be irish/indian mixed, but I aint hostile...lol
                  That would be the intake gasket.
                    Some reason the fellar at NAPA said it was listed as a Center Head Gasket....Oh well, at least we are on the same page now....lol
                      center head gasket, wtf. there is no spoon. your napa is run by morons. must be the same morons at the ford dealer cheesesteakjim has to deal with, and the napa morons 91ltdproject has. i'm so glad I actually can talk to competent enough parts store people to get the proper parts more often than not.
                        *UPDATE*
                        Fished out the missing piece of lifter
                        Prepped the head/Block/and all other gasket surfaces
                        Got the Double Roller Timing Chain and gasket
                        Just need the new head gaskets, the intake manifold gasket and the exhaust manifold gasket(Mine were TOAST)
                        Should have it back together by the 7th......
                        I will update when I get it running.....
                        -Wes
                          exhaust gaskets probably disintegrated when you pulled them loose. They always come apart like that.
                            Yea...they just fell away....
                              Finally found the Specs on the cam I got, I know its prolly weak, but it work.....
                              Cam Lift-
                              Intake-.278
                              Exhaust-.283
                              Lift Exhaust-.453
                              Lobe Int-117
                              CTRS-113
                              SAE-
                              Intake-.283
                              Exhaust-.304
                              .050 Duration
                              Intake-.206
                              Exhaust-.221
                              Hi-Tech Engine Components Part #-204900
                              Thought I would just throw this out there.......
                              -Wes
                                **UPDATE**
                                Got the:
                                Intake Manifold
                                Exhaust manifold
                                Head Gaskets
                                All set to install after I get the last 4 lifters back from the Company......
