edlebrock at the junk yard
    so i checked out a junkyard a few months ago and found an old mercury that had an edlebrock intake manifold and a 4 barrel carb on it but im not sure what motor it could be. if i knew it was a 302 id grab the stuff in 2 seconds but im not so i was wondering if you guys could give me things to look for thatll help me figure out wha tit could be. id love to get a the stuff for half hte price it normally would be since i think i mihgt try building a crabed 302, thanks
    I believe the 302 and 351 Edelbrocks are the same....................
    Either way, you could clean it up and sell it for more than you got it for if you didn't need it, lol.
      if its cheap, get it. If you can't use it on your car, just turn it on ebay.
      you'd need to know the year and model of the car to really ID the motor. Could be anything from a 289 to a 460. You might find a sticker under the hood on the fan shroud or something that will ID the engine, but who's to say whats in there now is the original.
      351 intakes are wider. They do not physically fit on a 302. 289 intakes are identical tho.
        hmmmm. as long as the merc had an auto tranny i could use the carb too right? i htink after crhistmas ill go down there and see what the guys would want
        i wonder if i could find an ID number on the manifold and have edlebrock run it and find out what motor it has too?
          If you get the numbers, try this web site.... www.grandmarq.net/vb...
          Edelbrock intakes usually say 289, 302 or 351 right on them.....
          If you look at where the distributor bolts down and the intake is even with it, then it is a 302 intake. If there is a ledge and the intake is higher, then it is a 351. If you look at the timing cover housing and where the heads bolt down, you can also tell. A 289/302 has a shorter deck so the heads are even with the timing cover. A 351 has roughly a higher deck so the heads are an inchish higher than the timing cover.
            few months ago? it's gone mostlikely
              Pre-AOD cars used a totally different trans kickdown system. You'd need a Lokar cable to run a carb with an AOD. Its a simple bolt-on part, there are no specific carbs for autos or aods really.
                You believe wrong mang........
                  Factory AOD carbs have linkage for AODs. Only the 1990-1991 VV cars use a cable linkage.
                    those are factory carbs tho. aftermarket carbs like the edelbrock aren't sold specifically for aod cars.
                      Suuuure they aren't......
                        I mean... they sure aren't........ :p
                          You should've taken it! You could've always sold it if you couldn't use it. It's gotta be gone now.
                            now can i just get the lokar cable and us eit on any carb or does it have to be a carb meant to be used with an auto tranny? ill have to go back this week and see if the stuff is still there and how muh hed want for it.
                              if it's still there don't show him the intake itself. Pay him for "the intake manifold and carb off of that car" and point at the car. THEN remove them and immediately put them in your car without him getting a close look at either one. Don't hide them from him (it'd make him suspicious as to why you're being sneaky), but try not to let him get a detailed look at them. If he realizes it's an Edelbrock with a 4bbl he'll almost definitely skyrocket the price... dunno about you but most junkyard guys I've personally dealt are jerks who just want to screw you out of some money.
