i had some down time at work one day and decided to look at factory cams from a few 302s and got these specs and prices from sealed power.
1990 bronco - 183 int, 192 exh @ .050" lift, 108 lobe separation $75.00
1990 mustang - 210 int, 210 exh @ .050" lift, 115 lobe separation $306.00
1997 explorer - 186 int, 197 exh @ .050" lift, 115 lobe separation $220.00
so if im doing this on a budget and i dont want to go to the junk yard for a cam id go with the bronco cam.
the big thing is im wondering how big of a difference there is in these cams? especially between the bronco cam and the explorer cam? also i was wondering if the bronco cam is better then a lopo cam and how much better if it is? any help and/or information is appritiated.
