Alright guys, Last night I picked up all the stuff for the HO conversion minus the ECU and throttle body. Heads are rebuilt with new Valves and springs. But anyway now I'm thinking if I'm gonna make the effort why not go a bit further. The E7's are staying, but is there a bit more aggressive cam I can run? I think it's b303 or something along those lines I've heard tossed around. And for the intake, I know I could benefit from a gt40 intake but how about the typhoon I've heard about? or is that too much Intake? as for the throttle body should I go 60mm Ho or 65mm Explorer? I know this is probably beating a dead horse, but I know you guys won't mind...lol. Also when I have the transmission apart for the HP shift kit should I install the govener supplied with the kit?
thanks in advanced, Dave
