i really don't understand how the adapters work. i mean if you use your old studs to mount the adapter and then use the adapter studs on the wheel, wouldn't the old studs stick out and interfere with the rim. i dunno, i guess i just can't picture it
found rims, got question
Stock studs are not long. They might stick out a hair, but not much. Hence the reason you run adapters and not slip on spacers.
Those are 1". The 1.25 are for stock brakes and fittign centercaps on bullitts, cobra, etc, wheels. 1" should work for you and those wheels as long as the mounting surface isn't flat. I had an issue with stock 94-95 wheels because they didn't have the reliefs like the bullitts and cobras..Builder/Owner of Badass Panther Wagons
