f4 truck block
    f4 truck block
    the f4 blocks have the explorer cam correct
    say i was to harvest a f4 longblock and i dropped it in one of my beater vics and used a gt40 lower and an explorer upper and a 65mm throttle body
    would it run with speed density and 19 lb injectors?
    ugha
    say i was to harvest a f4 longblock and i dropped it in one of my beater vics and used a gt40 lower for a 351 and an explorer upper and a 65mm throttle body
      Personally, I think you should give it a try!
        i'd like some input before i drop 600 bucks on a used motor and a 351w gt40 lower hehe
          So still no one has done this? I'd be real tempted to give it a try myself... especially if I already had most of the parts laying around.
            It'd prolly run OK...
              What kind of heads does it have on it?
              Nick
              88 Colony Park LS
                E7s come stock
                  Why not just harvest the harness & computer with the engine? Couldn't add that much more cost if its from the junkyard.
                  Look into pickup/bronco engine mods and see how well they run. Fullsizebronco.com has a good forum.
                  -Matt
                    Wasn't that motor batch-fire from the factory like the truck 302s? If so, I imagine part of the idea would be to have SEFI ...
                      I don't know if the mass air trucks were batch or sefi. I know it changed in 94 or so with the cam and all.
                        Arnt the efi trucks running 19# injectors not shure maybe thinking of the 5.0s. Should work might hav to do a bit of tuning.
                          skippys 97 f250 with the 351w has 19 lb injectors it's got gobs of torque.....that's what i'm after here on a low budget.......will it run on a speed density ecu for a 302 ho?.......truck wiring is all different.....i dont wanna go hacking and splicing.....i dont even want to bother with maf......it's not gonna be a race vehicle, just a daily driver.
                            Mustang Speed Density computer with a chip? Why not do a MAF conversion? Only a couple of more wires.....
                              Should work might help to have adjustable fuel pressure regulator. Playing aroud with the timing a bit. Cant be any worse than my set up.
