I have an 87 Vic with a 93 Cougar's AOD in it. 1-D-OD pattern. The trans will shift 1-2, then 2-3 just fine, then neutrals out in OD. At 30 MPH if I drop it to 1st is will grab and hold second, telling my the internediate band is good.
My first thought was that the valve body may have a clog or bad gasket/stuck check ball etc. I also thought the 3-4 servo may be bad, however since it neutrals I know the servo is ok as bad ones will cause the tranny to hold 3rd gear. Before I tear into the pan, does anyone have any thoughts or maybe know of a specific problem area to look for?
Thanks in advance.
Thanks in advance.
