Originally posted by 1987cp
View Post
Aod Govenor
I just bought the Bauhmann kit, we'll see how that works. Will I still need to change the shift governor with this kit? Reading on Bauhmann's website makes it sound like no, but I'm asking to be sure
It's -1 up here right now and the old girl is running like a raped-ape1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
So then you probably want either a stock replacement or something more like a TorkMaster 2000 or 2400?
I'm sure you've mentioned before, but what all's going into the engine that will be in front of it?2012 Mazda5 Touring | Finally working on the LTD again!
dont buy a b&m torque convertor.....they are junk, brian has seen a few grenade
call these guys i just googled the name.......excellent convertors these are the ones that brian uses.......i'm gonna reccomend the 1989-1992 thunderbird supercoupe convertor.....it stalls around 2 grand (stock vic is 1600 iirc) they can make you any convertor you want any stall heres the name and phone number
a perfect shift
(570) 424-6448
Originally posted by lincolnmania View Postdont buy a b&m torque convertor.....they are junk, brian has seen a few grenade
a perfect shift
(570) 424-6448
and GR, I'd personally be thinking something like a 2000-stall with that cam, depending on how the heads flow. Have you tried punching the flow numbers into something like Desktop Dyno?2012 Mazda5 Touring | Finally working on the LTD again!
Depends on what you want. I have a Supercoupe converter in mine from these folks, and the entire trans job was very reasonable, so I doubt the converter was a huge expense.86 Lincoln Town Car (Galactica).
I'd get around an 1800-2k, Stock HO's benefit from 2400-2800 stall however.... The explorer cam should have a bit more bottom end than the HO cam. I was not happy with a 2K stall and 3.73's on a stock HO in my 87.Builder/Owner of Badass Panther Wagons
Originally posted by gadget73 View PostThe governor mostly affects wide open shift points, not part throttle. Your part throttle shifts are mostly controlled by the TV pressure. Back it off just a smidge and they will drop. Don't go too far or it will shift like mush and accelerate wear on the trans.
Mike
