Aod Govenor
    Aod Govenor
    Where can I get a govenor for the aod trans thats in a mustang? And how much would a new one be? and how much should I pay for a used one if I come across one?
    Also, does anyone have a tech article on how to change it. Its on the tailshaft isnt it?
      they are under 20 bucks from ford
      tailshaft comes off, govenor held in with 2 bolts
        does anyone have a pic of one?
            thank you
              So the part number is E8ZZ-7C063-A? Were there other part numbers for the 5k-rpm governor?
                Don't use it if your engine is stock, it won't shift at WOT.
                Nick
                88 Colony Park LS
                  that's the only hi speed govenor available from ford michael
                  if you want higher wot shifts you need to get the transgo hp kit......it has the govenor mod
                    The Transgo AOD-HIREV shifts at more like 5500, no?
                      i know with the wide ratio's and the lopo govoner it's 5200 wot shift
                        so by doing an HO conversion, should i be changing the govenor?
                          yes
                            whats gonna happen if i leave the stock one in?
                              4200 rpm wot shifts
