check engine light, funky throttle
    I just got her running, and shes doing good. Except this problem:
    I turn on the car, idles fine, idle drops 2 seconds later
    then check engine light comes on
    then when I hit the gas there is a delay before power kicks in.
    Throttle position? IAC?
    yep, any of those two - my Shadow was throwing a CEL till I cleaned both the IAC and the TPS, CEL is now gone and all is good.
      Might want to check it for codes, it'll tell you whats wrong. Probably TPS though if I had to guess. The IAC is raising and lowering the idle so its probably fully functional.
        hmm, advance auto can't check the code cuz its too old?? Where is the code checker plug on my car anywho. I could buy a code checker if need be, but what kind would i need?
          Test light and a jumper wire is all you need. Test connector is up near the washer bottle. If you're buying one, you need one for a Ford EEC IV. I'd get one with a digital readout. The blinky light ones are nothing more than a jumper and a light.
          If you want to do it on the cheap, here ya go: http://fordfuelinjection.com/?p=13
            It was the TPS, I replaced it with Anabelle's original lopo unit I thought I had thrown away. Yay for no more CEL.
