Ok, back to driving the LTD again. I'm having trouble with the engine light. Is this a possible vacuum leak? The car runs perfect but the light will come on and go off. If you step on the accelerator, the light goes off but if your are idling at a stop light, the engine light sometimes illuminates. I have checked all fluids and everything. The car is doing great. The engine runs just like it should so that's not an issue. Any ideas guys???
Possible Vacuum leak???
your 81 has the "replace engine" light... its not computer controlled at all. Im thinking your oil pressure is low at idle... as long as its going off as soon as you acellerate, you have many happy years leftPete ::::>>> resident LED addict and CFI defector LED bulb replacements
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Do you have an oil pressure gauge? Like Pete said, textbook low oil pressure symptoms.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Sounds like the engine's just getting worn out...was it abused at some point in its life (lack of oil changes and such)? How many miles are on the car?
Worn out bearings is usually the low pressure problem. Usually its also accompanied by that wonderful knocking noise on a cold start, and bearing noises if the engine is under no load around 1500-2000 rpm when hot. Just a side note, if the engine is idling way too low, it can also make the pressure go too low. Idle in gear should be like 650 rpm or so.86 Lincoln Town Car (Galactica).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
It's probably not in any immediate danger, considering all the stories you hear about guys running the things with virtually no oil pressure at all, and doing so for extended periods of time. That said, what weight of oil are you running? Could bump that pressure up a bit with some heavier oil, though there's another school of thought that says low oil pressure means there's lots of oil flow. I'd say there's something to that.
I don't know what you had in mind for this engine, but I wouldn't plan on anything too drastic...might as well start with a healthy bottom end before you play with the top end.
Doesn't really matter if it was abused. Lopo 302s usually either start with the knocking dead bearings around 120k, or they run for ages with perfect oil pressure. Doesn't seem to be much in between. It has to do with the firing order wearing the mains, I think the #3 is the one that takes the pounding. Just keep oil in it, and don't bounce it off the end of the tach, and it'll run for quite a while like that.86 Lincoln Town Car (Galactica).
my 2 door that i am having an engine built for was like you car. after it warmed up the engine light would come on at idle but be gone as soon as you touched the accelerator. low and behold the oil pump or something went out on my way home from werk and i am just having an engine put in that i will like in it. my 2 door had heads redone but lower was never redone so the lower components failed. car had heads redone before i bought it. i would be careful and if the light comes on and stays on all the time ... shut it off and get a tow
i've had a really quiet knock on the 86 that goes away slightly when warmed up. been beating the shit out of it for 6 years that way.
does it kinda sound like a diesel?Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
Originally posted by cld783 View Posti've had a really quiet knock on the 86 that goes away slightly when warmed up. been beating the shit out of it for 6 years that way.
Not really. Mine doesn't make much of a knock at all. It's so quiet that you have to really listen close to hear it. It only does it for about 3 seconds on a cold startup and then it quits as the car warms up.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Yeah, you're probably hearing the mains knocking a little bit. My Lincoln does that from time to time. 178,000 miles and about 5 psi oil pressure at hot idle with 5W30.
tsk, you should be using at least a 10w30 per the factory documentation.86 Lincoln Town Car (Galactica).
