I'm running a big 1g battery cable off the alternator to a 200A fuse, then to the battery. I've run into a conundrum, however. I'm looking for opinions here.
-- I could run it nearly along the cowl around the engine to the fender apron, where it'd plug into the fuse. That'd require nearly 11ft of battery cable, which would prove difficult to find because I'd like to avoid having to cut my own and I haven't found anyone who sells any besides PA-performance, and they're kind of a ripoff IMO.
-- I could run it over the engine, between the intake, disty, A/C compressor, etc. over to the fender apron into the fuse. This is what I'd prefer to do, but I'm hesitant because I don't know how much heat it'd take to damage these cables.
Those who have done this before, what did you end up doing?
