going down Dodge street heading towards 146th. my car starts shaking like crazy!!! (it wasnt all at once, it develops while i was headint down there)
so i pulled over and both my front brakes ,mostly the driver side, were smoking like there was an actual fire. i had to drive from 150th and dodge to 95 and harrison, i had to pull over every once and a while to let them cool down, the more the heat up the harder it is to get going.
so i'm #$@ right? i dont know what to do. i belive i will have to replace both front rotors and get shoes for them, plus all the misc, ill need for the job. but from all that heat, what else could i have #$#@ up?
i have read in the tech archievs about replacing front brakes. but monty brakes werent locked up like mine are ( it is locked up right?) so i dont know where to begin. can you mangs help me?
i would like to try this myself, yet cause of all that heat, there might be more of a problem then just replacing the rotors, brake shoes, ect...
should i just go to the shop instead?
Dave
Dave
