H.O. intake install ?
    Hey mangs,
    I recently recieved an H.O. intake with egr spacer and throttle body from a fellow mang here on GMN.
    It must be my noob brain but i cant belive is it just a simple switch from stock intake to H.O. intake? just bolt on and go? is there any need to remove the coolent, de-pressurize the fuel line, ect?
    I just need to remove the eletronic stuff that on the stock intake. remove the breather, vacum lines, and just swap it?
    and if so, do any of you mang have any tips before i swap the intakes.
    sorry for wasting your time for my nobbish question but any info would be greatly appreciated.
    Dave
    http://www.cardomain.com/ride/2681604 --- http://www.supermotors.net/17596
    The Throttle Body you have, has the throttle lever been turned around so you can hook it up to your throttle cable and TV cable?
    You might want to drain a little coolant since the EGR spacer has coolant in it (and the two lines going to it).
    No need to mess with fuel lines unless you are fooling around with the lower intake or swapping injectors.
    Make sure you label the vacuum lines before pulling everything apart. Also make sure that the mating surfaces between the lower and the upper intake are clean before installing the new intake and gasket. This would be an ideal time to replace the old vacuum lines and EGR cooler lines (they see the same psi as the rest of your cooling system), and make sure to replace the PCV screen while it's easy to get to (with the upper intake off) if you haven't recently.
      The injectors and fuel lines are not touched. Take off the coolant and vacuum lines on the uppers, make sure you note where they went. Unnplug the connectors for the TPS and EGR, Pop off the thottle and TV cable linkages, unbolt the throttle cable bracket, take off the intake plate, take out the 6 bolts, lift off the upper intake. Swap the vacuum ports around on the HO, using the lopo ones if needed. Swap over the EGR spacer (hopefully you have a ported one and new gaskets) and the modified HO TB, and reinstall everything using a new or good gasket.
        i definatly will change the vacume lines and EGR cooler lines while i'm changing the intake. and by any chance do you know what diameter they are?
        also what is the PCV screen? is it PCV valve? should i just replace teh pcv valve?
        and mrltd, thanks the the info you provided!!
          I know the EGR Cooler hoses are 1/4in, as is the vacuum line to the MAP sensor. Seems like I used some 5/16in on the PCV valve and on the rest of the vacuum lines under the upper intake. Make sure you get good hose for the EGR cooler lines. I used rubber fuel hose to stand up the pressure.
          The PCV screen is a metal screen under the PCV valve. It gets stopped up with junk and causes problems. As a rule of thumb, always change the screen when you change the PCV valve
            yea, it would be a good idea to change out that PCV screen when you have the upper intake off....it is possible to swap it out with the upper intake on, but it's a PITA.
            I was on top of my motor doing it.
            it didn't want to come out easy...but you should get it out with a pair of NeedleNose pliers....dig into it and grab it if you have to, thats what I had to do.
            it looks like some steel wool in a little cylinder...about 1" long.
            should only be a few bucks at an auto parts store...I believe they call it like a PCV breather element IIRC.
            that HO intake shouldn't give you any trouble...it came directly off mine.
              the PCV screen is the crankcase filter element or something along those lines.
              also i installed it today, WOW what a difference! Thanks colin for the intake! and tiggie and mrltd for the tech help.
                oh, got it on now? sweet! that was quick.
                you're welcome....glad it's working good for you....makes throttle response a little better dont it?
                was it pretty easy to do?
                  well i tried last night but all i did was take off the stock upper intake, so i had at it again today after school. total time was about 41/2 hrs. ( note, that i dont have any mechanical experience, and i also changed my alternator too.)
                  and yeah it was pretty easy to do most of it, there some parts where i need an extra hand.
                  theres only one problem................. my check engine light is on and i dont have a scanner i'm going to buy one soon. and figure out what is wrong...
                  as i also need to buy another Plate, the one that says 5.0L Ford. i broke the one that was on the stock intake cause i stripped one of the bolts and i had no way of getting it out. also broke the small vacume canister thing, and broke the breather line that going from the head to the TB...
                    Double check all the connectors and vacuum lines.Also make sure the TPS was installed properly
                      I'm sorry but what is TPS?
                        Throttle position sensor.
                          that would be the electrical thingy on top of the TB IIRC....the thingy on the side is the IAC(Idle Air Control valve)....might be a good idea to clean yor IAC as well...always help to keep idle smooth.
                          if the engine light still stays on..take it to a AutoZone/Murray's/Advance...they can scan the code for you for free...if needed.
                          I still have my plate for the intake if you really want it....I kinda sprayed it with some of the Alluminum paint...but if you need it, you can have it.
                            also you might want to replace some of those vaccum lines now that your in there so I think they will most likley brake when you pull the vaccum lines off. you might want to change the valve cover gaskets if they are leaking. also do not use silcone vaccum lines they will brake easy
                              Gabe here speaks the truf.
