any suggestions on water pumps? Mine is leaking a bit.
Any real difference in brands?
I tow some so cooling is high priority.
2000 Grand Marquis LS
Mercury Owners Group member
Workig on replacig mine as we speak. Went with the duralast new 40.00 pump. Reman one didnt look so bood around the outlets going to the block. Painting the pump now. Prob 2 days or so before install.
I got a NEW HD cast IRON one from autozone. It's used in the cop cars and some of the tow package cars. I have a nasty habit of blowing gaskets out. The cast iron one fixed that problem. It has 2 extra bolts.
Thanks, that's what I figured, no issues bolting to my block correct?
i hope the pump bolts don't brake lol my current pump is a sig series pump brandy new from advance 47 dollars don't get remain pumps ray there junk
my water pump is a remanufactured/rebuilt.....it has been serving me fine. i got mine from o'reilly auto parts. i changed mine out before going to SF this last summer and it was in REAL bad shape.
i had a reman from napa, started leaking in 10k, new one from i forget, 8k and the gasket blew out of the back of it. got annoyed and put the cheapest pump i could get on there, like a $15 reman. Its been on there 20k miles and has been off twice now I think, no problems. Win some, lose some.
Might want to consider a timing chain while you're in there. The 85 would have that plastic geared piece of crap that wears out way too soon.
get the water pump for a 1985 crown vic with a 351w ray.....cheap with my discount....need help with it.....i got a nice warm shop....and please change the 1985 hoses.....i know they got low miles but if you disturb them, they are gonna leak
Thanks Scott. I think I can get it. I will replace any hoses that I touch. The money I would spend on gas would of set any savings on the pump.
Gas is close to 3 bucks lately.
Thanks
My dad told me when installing a new water pump to remove the cover on the back of the water pump and put some RTV on there to keep that seal from crapping out on ya. I too replaced a fairly new Napa pump because it was leaking on the back cover (previous owner installed it). I installed a remanufactured pump I bought at a swap meet for $10, it was a old Advance Auto Parts pump before they started using CarDone.-
