Look @ this 90 TC EGR Spacer
    A :banana: to the first person who can spot what's different about this 90 Towncar 5.0 EGR Spacer vs the Regular Box 5.0 EGR Spacer.Without first comparing it to a pic of the Regular Box EGR Spacer,don't cheat!
    it's bored out?
      no threaded studs in it?
        What is it?
          you got me :confused:
            what ever the difference is, the one you pictured has a crack in it. look at the first picture at the top left.
              that might be the difference. I see it now good eye!
                doesent look quite as deep as other yrs
                  Coolant ports are both on the back side of the spacer, vs. one on the front and one on the back like most box spacers are. Why is it so important tho?
                    front/back cooler line arrangement is Fox, both rear is standard for a panther.
                    Looks like the air bleed groove might be deleted from this. I seem to recall the standard ones having a channel milled into the piece of metal that goes from the center hole to outer edge. Its also missing the studs for the EGR valve.
                      Soo....Custom87, what is it?!
                        Looks just about like how I remember my old spacer looking. I'm thinking the bore might be slightly smaller, though .....
                          egr is clogged shut
                            you can tell that from the picture?
                              Oh yeah, forgot I'm running a Fox intake setup, plenum and all. Theair bleed channel ain't there on all of them tho, the stock EGR spacer on my Townie didn't have it.
