Originally posted by LTDMan83
View Post
Exhaust options
Originally posted by torquelover View PostA change from a 2:73 to a 3:27 cured mine. You don't remember my car droning, do you Michael? I thought Delta Flows were supposed to drastically cut the drone? I have old school 2-chamber flows.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostInteresting. 'cause if I could put my Flowmasters back on without a nasty drone....... I've got a set of 2.5" in/out 40 Series Delta Flows laying around. What model do you have?
I love the sound,but I recently got to hear the new 44mag Delta Flow series,long story short,I'm now sold on them.I'm actually planning on swapping some in as soon as $$$ permits.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by MeLikeyStripperChicks View Postthey even made 2.26 gears? damn, that must take forever to pick up speed
Originally posted by LTDMan83 View PostI have the 40 Series 2-Chamber Flowmasters,which aren't the same as the Delta Flow series.
Hm, weird - appears they're no longer marketing the old 40 Series, the original two-chamber with only one internal deflector. Interesting the new variations they've introduced:
Super 44:
Super 40:
40 Series Delta Flow:
Originally posted by MeLikeyStripperChicks View Postthey even made 2.26 gears? damn, that must take forever to pick up speed86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Post79's with the C4 tranny got them. It was an attempt to make some fuel economy with only 3 gears. They probably did suck, 128 hp, 4,000 lbs, 2.26 rear. Yeah that just screams performance
Although, it's still somewhat entertaining to be able to go 70mph in First gear at a comparatively low 5,000 RPM. Theoretical top speed in this car given sufficient top-end power and high RPM's is just plain scary. Let's see ....... proportionally speaking, 7,000 rpm in First would be maybe 98 mph ...... First gear being about 2.4:1, direct-drive would give perhaps 235mph at 7,000 rpm in Third.Last edited by 1987cp; 11-20-2007, 01:44 AM.2012 Mazda5 Touring | Finally working on the LTD again!
C4: 2.46(1st) x 2.26(rear) x 26"(tires) x 2000rpms = 28mph
TH350: 2.52(1st) x 3.07(rear) x 32"(tires) x 2000rpms = 25mph
The C4 passenger car combo will reach my 25mph at 1800rpm, which is only like 10% difference - not bad, not bad at all. However, as I said low-end torque is needed, lots of it - Mike, what is your 306 supposed to have, according to the desktop dyno?
When I had 2:73's, I swear the car was still "On the converter" across the intersection. The car would boom like mad from 35-40 MPH all the way up until about 75 MPH. The 2.26 rear must have been rough, but maybe less so because of the C4. When I was at my buddies house last (1987cp was also in attendance) he had my old-school 2-chamber Flows off my Mustang still in his garage. They were offset/offset, 2.5". Anyone want them, PM me and I'll see if they're still on his shelf.
Here's an easy site for what you guys are doing:
http://www.f-body.org/gears/
Originally posted by MeLikeyStripperChicks View PostWell since you brought up the 1st gear ratios:
The C4 passenger car combo will reach my 25mph at 1800rpm, which is only like 10% difference - not bad, not bad at all. However, as I said low-end torque is needed, lots of it - Mike, what is your 306 supposed to have, according to the desktop dyno?Last edited by 1987cp; 11-20-2007, 03:19 AM.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by MeLikeyStripperChicks View PostInteresting, wonder how my 350 compares to all that, it pulls real strong even with the 3.07 rear gears and 33" tires.... What data you need to dyno an engine in your program? Alternatively, where did you get the program from?2012 Mazda5 Touring | Finally working on the LTD again!
