i have an issue with my 91.. its got a rough and sometimes erratic idle, and a mis fire when under a load... and it seems like i have to turn my idle up all the time... like it slowly drops down lower. engine light comes on rarely, cant check the codes cause my plug doesnt put out a signal. ive done a tune up of course, didnt help. any ideas? thanks guys
Constantly adjusting the idle... ???
you think thats the only possibility? i just dont wanna go changing $500 worth of electronics to find the problem. im going to carburator with the HO swap in a couple months, but the gas milage is KILLING me at 6mpg right now! thanks
grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
there, now im cool too
the screw is a throttle stop screw, not an idle screw........first clean the throttle body, and remove and clean the idle air control valve.........put it back on, if the idle is better great, if not it may need to be replaced. also a faulty throttle position sensor could be causing the problem too
dont rely on autozone to check your codes, you can get an inexpensive code reader at just about any auto parts store, and walmart
there are 2 plugs on the eec4 setup a large kinda triangular one, and a single wire plug..........you cannot scan without using both plugs.
good luck!
scott
Originally posted by lincolnmaniadont rely on autozone to check your codes, you can get an inexpensive code reader at just about any auto parts store, and walmart
good luck
hey you guys rock, the moron DIDNT hook up a single wire... just the triangle one. thanks. i think i may pull those parts off my 1989 GM with 89k miles and see if they clean up the idle on my 91. maybe ill go tinker with that RIGHT now cause im SOOOO fuckin bored! thanks again.
